Buderus antifreeze
PurpleKayak
Member Posts: 4
in Gas Heating
I have a Buderus Logano g124x furnace in my home (bought my house in 2019, furnace was installed in 2002). During our annual maintenance visit, the tech noticed a bucket of Utility NoFreez sitting next to the furnace and said that the system needs to be flushed because this antifreeze can’t be used with our system. I’ve searched everywhere, in the manual and the internet, and can’t find any information on the correct antifreeze for this system. I know it’s a cast iron boiler, but why does that require aluminum-safe antifreeze? Thanks!
You have the correct product in your system. That is what it is made for. Here is the literature for it.
https://www.utilitychemicals.com/pdf_files/No Freez .pdf
But don't be too hard on the lad. He probably was told to be careful with the proper antifreeze because there a number of aluminum boilers in service now. Buderus makes one. Yours is not that one.
We all start learning somewhere. 'Good judgment comes from experience; experience comes from bad judgment'.
BTW you have a boiler. A furnace is connected to ductwork and there is no water involved.Edward Young Retired
2 -
Thanks for the feedback. He also put in some AF during the annual service call, but it wasn’t until his follow-up to check the freeze/burst ratio that he said something about us needing aluminum-safe AF. So now I’m wondering what he put in during the servicing. Ugh.Ironman said:Your "tech" is wrong, Buderus doesn't require any special antifreeze for a cast iron boiler.0 -
You are probably fine, You can put aluminum safe AF in a Cast-iron system. You can't put Utility No Freeze in an aluminum system.
The guy who knows a lot about water quality and antifreeze is @hot_rod
Now that I mentioned him, he will get a notification and be able to comment.Edward Young Retired
LOL. I grew up in South Florida and now live in Maine so this is a whole new world for me! The guy is pretty young so I think you’re right. I guess as long as he put regular AF in during the latest service then we should be all set. Thanks!EdTheHeaterMan said:BTW you have a boiler. A furnace is connected to ductwork and there is no water involved.
ETA: I see your new post and sounds like we’re okay either way. Thanks.0 -
Update: a different guy showed up planning to put in 5 gals. of NoFreez concentrate. Refractometer showed freeze/burst of 23 degrees/23 degrees. We live here year-round and have a wood stove next to the furnace, plus a generator, but I had him add 2 gals just to give us some elbow room. He also replaced an automatic air release valve.0
- 15.8K Strictly Steam
