Hydronic Question
mpozz
Member Posts: 2
I have a 320 sf shop with a 2 loop 1 zone system cast into the slab. The slab sites on 3” of foam. I’m looking for suggestions on a heat source. Most boilers are too large. Any thoughts on an electric point of use.
A small electric boiler would be ideal, but possibly a small tank water heater depending on the actual heat loss of the space0
You can use a small hot water heater. For a space that small in a closed system, just about anything made for hot water would be enough.0
Or a small gas or LP fired water heater, if the fuel costs are lower. While the output is too large the 40 gallon tank is an ideal buffer. What are your true KWh costs. Gas or LP?Bob "hot rod" Rohr
Living the hydronic dream0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
