Weird Push Nipples (Pictures)
AdmiralYoda
Member Posts: 793
Sorry, I had to....but I've got some weird nipples. You guys have given me some great advice on splitting the radiator sections and I finally got the sections apart but the nipples don't seem to be a standard size.
The crown measures 1.475 (so 1.5") which Oswald Supply doesn't seem to carry anymore.
So what I think I'm going to do is just remove the next section which has a good nipple and reuse that one.
One question....what's the best way to clean the gunk out of the flange area? I was thinking a mild cleaner/degreaser like Simple Green and a Scotchbrite pad.
Anyways, as promised....here are some pictures of my nipples.
A wire wheel on an electric drill will do the job just fine.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Yup! Since replacement nipples aren't available I removed a section and salvaged a good nipple. I used a nylon brush and some Simple Green then used a Scotchbrite pad and some steel wool.
Loaded up the flange with RTV and beat the snot out of it with a small sledge and a piece of wood to seat the sections together.
So far no leaks...1
- 50 Industry Classes
