Leaky pipe at site of bracket
stevenM
Member Posts: 15
I am a novice.
I have a gas heating system.
I have this leaky pipe, at the point of some bracket, in the heating system that been leaking for years and now its getting worse. The pipe is near the basement ceiling.
What could this be?
If appropriate, what would the price range of fixing this? I just don't want to be ripped off.
Steven
Thanks in advance
Steven
What could this be?
Steven
Thanks in advance
Steven
Anyone? Thanks0
We assume that this is steam??
This was a band-aid installed some time ago.
We do not talk pricing here.
Is the pipe enclosed in a soffit of some sort?
Can you see the fittings in either direction?0 -
Try calling a few plumbing or HVAC companies, maybe they can give you a ballpark estimate. Pricing varies by region and isn't discussed here.0
@SuperTech thanks0
If there's serious corrosion of the steam pipe, it should be replaced.0
Ok, thanks0
@stevenM
Most will not quote a price for a job like that. It's a T & M job and does have to be fixed.
Where are you located? Try "find a contractor" on this site0 -
@EBEBRATT-Ed
OK I'll try it, thanks.0
- 123 Chimneys & Flues
