Leaky pipe at site of bracket
stevenM
stevenM Member Posts: 15
I am a novice.
I have a gas heating system.
I have this leaky pipe, at the point of some bracket, in the heating system that been leaking for years and now its getting worse. The pipe is near the basement ceiling.
What could this be?
If appropriate, what would the price range of fixing this? I just don't want to be ripped off.
Steven
Thanks in advance
Steven
  • stevenM
    Anyone? Thanks
  • JimP
    JimP Member Posts: 100
    Could that "bracket" be some type of leak repair clamp? Maybe there's a rubber liner that has deteriorated. You could try to replace that clamp with a new repair clamp.
  • JUGHNE
    JUGHNE Member Posts: 11,548
    We assume that this is steam??
    This was a band-aid installed some time ago.
    We do not talk pricing here.
    Is the pipe enclosed in a soffit of some sort?
    Can you see the fittings in either direction?
  • stevenM
    @JimP thanks for responding. It was like that when I moved in 20 years ago. I am not equipped to do it my self. I guess I’ll look for a plumber.
  • stevenM
    @JUGHNE thanks. It is a steam system. It is in a soffit but I could try to see what the fittings are.
    Where would I go to get an idea of price?
  • SuperTech
    SuperTech Member Posts: 2,655
    Try calling a few plumbing or HVAC companies,  maybe they can give you a ballpark estimate.  Pricing varies by region and isn't discussed here.
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    From the mechanic who knows how to do the repair properly. That pipe (and hanger) should probably be replaced.
    ethicalpaulmattmia2
  • stevenM
    @Paul Pollets, thanks
    What does the hanger mean?
  • stevenM
    @SuperTech thanks
  • Paul Pollets
    If there's serious corrosion of the steam pipe, it should be replaced.
  • stevenM
    Ok, thanks
    EBEBRATT-Ed Member Posts: 20,090
    @stevenM
    Most will not quote a price for a job like that. It's a T & M job and does have to be fixed.
    Where are you located? Try "find a contractor" on this site
  • stevenM
    @EBEBRATT-Ed
    OK I'll try it, thanks.
