Smoke test
Boobie69
Member Posts: 13
in Gas Heating
Hello,
Can you perform a smoke test on a boiler that is not running? 2 plumbers are telling me that my chimney needs to be relined and it failed the smoke test...yet boiler not running. Just wanted to see if I was getting BSed.
Thanks
Thanks
I agree with Jamie. I can usually tell if a chimney has issues by visual inspection when I remove the smoke pipe or while checking draft during the combustion analysis process. I always recommend that my customers refer to a chimney specialist address any concerns and evaluate the condition of the chimney.2
@MikeL_2 Why did you disagree with what @SuperTech posted?SuperTech said:Sounds like BS. I've never heard of a smoke test for a chimney inspection....and you have gas heating? As an HVAC technician a smoke test for me is something I do with oil burners, but its part of checking how the burner is operating. Not the chimney.
Our utility used a smoke test on the sewer system.
They were looking for open pipes that might allow storm water into the sewer. Smoke was supposed to come out of roof vents only.
Some people had it in their basements from dry traps etc.0 -
Oh those are fun! I've done a few cities...JUGHNE said:Our utility used a smoke test on the sewer system.
Some people had it in their basements from dry traps etc.Br. Jamie, osb
Being a small village we were able to notify people via the weekly newsletter. Other wise you may get 911 fire calls.0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
- 19 Recall Announcements
