Honeywell t775 boiler rotation
metrosilo
Member Posts: 34
Hi. I'm looking to install an automatic boiler rotation controller connecting two boiler. I want them to rotate or flip flop between them so they have the same run time.
I'm new to installing controls but I'm familiar with the Honeywell t775 but I haven't installed a staging control before.
I found that the T775P is the multistaging controller I would need but when I look in the manual, it doesn't mention anything about rotating between boilers. It just states that when temperature keeps dropping, the different stages are activated Does 'staging' always mean that the boilers will automatically rotate?
I'd like to use this controller if possible. Anyone familiar with this.
Can’t go wrong with Tekmar.
http://www.tekmarcontrols.com/products/hvac-systems.htmlThere was an error rendering this rich post.
Rotation is separate from staging. I can't recall for sure if the T775 supported rotation, but I suspect not. There are rotation relays available, if you're determined to use the T775s.
While there's something to be said for an integrated approach, using what you're familiar with (& can easily service!) is a real thing too.
Yes to the tekmar. I found the tekmar 265 that suporta staging and rotation. I'm definitely familiar with tekmar so I might go down that road.
Correction. The 265 is not available. The 284 is the replacement.0
