A 4 Month Project Nears Completion
New England SteamWorks
Member Posts: 1,526
We're just completing a fun project that we thought we'd share for your enjoyment, and also as a demonstration that we are still alive. Just too busy for anything else but work...
Our customer purchased a new single family home last spring that had two steam systems. Presumably the home was converted to a 2-family at some point. Then it was converted back, but the separate heating systems were left intact.
The original project was to remove the two boilers so that a new basement floor could be poured, then reinstall them.
But as the homeowner progressed with his basement renovation he began to desire more than simply a new floor. He also began to envision additional uses for the space. But there was a big problem. When they converted the original steam system into two, they made a real mess of the piping. It was everywhere, and often times very low. This made the rooms pretty much unusable.
So he asked us about getting the steam piping all up into the ceiling. After spending a great deal of time calculating and measuring, that wasn't going to work. But what could work we decided, would be to combine the two systems again. That would clean things up very nicely, especially if we buried the returns. But now there was another problem. Neither of the two existing (and relatively new) boilers were large enough. He'd have to spring for a new boiler.
We first met the customer is July, and will be finishing up his project today. So this project has been a long and winding one. And the poor customer will have spent more on his basement than most folks would spend on a home renovation. But at least everything is coming out very nicely.
newenglandsteamworks.com
Here are some before photos:
newenglandsteamworks.com0 -
Here is some of the old pipe we removed, freeing up a lot of space:
newenglandsteamworks.com2 -
And here are some photos from yesterday. We'll be back later today and I'll get some final photos to post.
newenglandsteamworks.com6 -
Beautiful Ryan, lot of work there......DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......4 -
No, those tandem steam jobs always end in disaster...New England SteamWorks
newenglandsteamworks.com1 -
@New England SteamWorks beautiful job as always.0
Well Tom, it wasn't 4 months continuous!New England SteamWorks
I suppose the cost of a boiler is trivial in all the rest of that work. Did they end up cutting the new floor for the wet returns?0
Yes, they cut the floor after pouring. More pics:
newenglandsteamworks.com3 -
I'm glad your back, We missed you Ryan.
Located in durham NC.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
