Cast Iron boiler repair
Boobie69
Member Posts: 13
in Gas Heating
Hello,
I have a very old cast iron boiler. Gas fired. We have a internal leak. It starts up and runs, but after a while, water is leaking onto the flame sensor, the pilot goes out. I have to go and restart the boiler and do the process as least 2, 3 times a day. I am worried about when the real cold hits I will not beable to keep this going. Had a plumber look at it and they said non repairable because it is a cast iron boiler...is that true? Am I screwed?
Any info from anyone would be great and thanks. Any other info you may need, please let me know.
For all practical purposes, your plumber is correct.Br. Jamie, osb
You need a new boiler. No question about it0
Thank you. I just wanted to be sure. DAM...right before winter...no luck at all..Thanks again. Stay safe.0
Hot water or steam?0
If it's not a big leak, you can try a boiler seal like this:Boobie69 said:Thank you. I just wanted to be sure. DAM...right before winter...no luck at all..Thanks again. Stay safe.
https://www.homedepot.com/p/Hercules-32-oz-Boiler-Liquid-30115/100147992
It's a temporary solution if it works at all, but it may buy you time to calculate proper size, type, make of boiler, and installer.
@Boobie69 , is this a steam boiler? Where are you located?All Steamed Up, Inc.
Consulting0 -
Sorry for the delay answer..not steam hot water.0
OK- try the "Find a Contractor" link above- you'll need someone who knows your system.All Steamed Up, Inc.
Consulting0 -
Thank you. I will check. I think the boiler needs to be shot. Thanks everyone for the help.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
