Cast Iron boiler repair
Boobie69
Boobie69 Member Posts: 13
Hello,
I have a very old cast iron boiler. Gas fired. We have a internal leak. It starts up and runs, but after a while, water is leaking onto the flame sensor, the pilot goes out. I have to go and restart the boiler and do the process as least 2, 3 times a day. I am worried about when the real cold hits I will not beable to keep this going. Had a plumber look at it and they said non repairable because it is a cast iron boiler...is that true? Am I screwed?
Any info from anyone would be great and thanks. Any other info you may need, please let me know.
    For all practical purposes, your plumber is correct.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,622
    You need a new boiler. No question about it
  • Boobie69
    Thank you. I just wanted to be sure. DAM...right before winter...no luck at all..Thanks again. Stay safe.
  • JUGHNE
    JUGHNE Member Posts: 11,604
    Hot water or steam?
    EBEBRATT-Ed Member Posts: 20,482
    You can try some boiler sealer. It won't put the replacement off but may keep the water from dripping on the sensor so you can keep it going in the meantime
    Intplm.gkimmeo
  • MaxMercy
    MaxMercy Member Posts: 609
    If it's not a big leak, you can try a boiler seal like this:
    https://www.homedepot.com/p/Hercules-32-oz-Boiler-Liquid-30115/100147992
    It's a temporary solution if it works at all, but it may buy you time to calculate proper size, type, make of boiler, and installer.
    Steamhead Member Posts: 18,714
    @Boobie69 , is this a steam boiler? Where are you located?
    Consulting
  • Boobie69
    Sorry for the delay answer..not steam hot water.
    OK- try the "Find a Contractor" link above- you'll need someone who knows your system.
    Consulting
  • Boobie69
    Thank you. I will check. I think the boiler needs to be shot. Thanks everyone for the help.
