Boiler Cleaning
fxrgrunt
fxrgrunt Member Posts: 157
Based off the recommendations over received I will be draining the boiler, wand cleaning followed by a skim. I already skimmed once prior to as well then fired the boiler. Water is much cleaner but still surges. My question is when I drain and refill should I add some surgemaster while it is empty per the products recommendation or should I only put water in the boiler? Trying to make sure I dont have to do this multiple times and get as dry steam as possible. Thanks.
    ethicalpaul Member Posts: 8,812
    You have skimmed your boiler? Out of which port?
  • fxrgrunt
    I used the T per instruction manual and clammys recommendation. Built contraption in attached picture to do it.
    EBEBRATT-Ed Member Posts: 20,195
    That's a good start
    fxrgruntethicalpaul
  • fxrgrunt
    Any recommendations in regards to adding the Rectorseal Surgemaster?
    Very nice skimmer you made there.
    My recommendation is to try about 1/3 of whatever Rectorseal says
    fxrgrunt
  • fxrgrunt
    @JUGHNE gave me the idea to reduce it from 2" to 1 1/4" so I have to give credit where it is due regarding that. Saved me $20 bucks atleast due to using the smaller nipple and valve as well.
