Boiler Cleaning
fxrgrunt
Member Posts: 157
Based off the recommendations over received I will be draining the boiler, wand cleaning followed by a skim. I already skimmed once prior to as well then fired the boiler. Water is much cleaner but still surges. My question is when I drain and refill should I add some surgemaster while it is empty per the products recommendation or should I only put water in the boiler? Trying to make sure I dont have to do this multiple times and get as dry steam as possible. Thanks.
You have skimmed your boiler? Out of which port?
I used the T per instruction manual and clammys recommendation. Built contraption in attached picture to do it.ethicalpaul said:You have skimmed your boiler? Out of which port?
1 -
Any recommendations in regards to adding the Rectorseal Surgemaster?0
Very nice skimmer you made there.My recommendation is to try about 1/3 of whatever Rectorseal says
See my sight glass boiler videos: https://bit.ly/3sZW1el1 -
@JUGHNE gave me the idea to reduce it from 2" to 1 1/4" so I have to give credit where it is due regarding that. Saved me $20 bucks atleast due to using the smaller nipple and valve as well.ethicalpaul said:Very nice skimmer you made there.My recommendation is to try about 1/3 of whatever Rectorseal says
1
- 128 Chimneys & Flues
