Boiler Cleaning
fxrgrunt
Member Posts: 157
Based off the recommendations over received I will be draining the boiler, wand cleaning followed by a skim. I already skimmed once prior to as well then fired the boiler. Water is much cleaner but still surges. My question is when I drain and refill should I add some surgemaster while it is empty per the products recommendation or should I only put water in the boiler? Trying to make sure I dont have to do this multiple times and get as dry steam as possible. Thanks.
You have skimmed your boiler? Out of which port?
ethicalpaul said:You have skimmed your boiler? Out of which port?1
Any recommendations in regards to adding the Rectorseal Surgemaster?0
Very nice skimmer you made there.My recommendation is to try about 1/3 of whatever Rectorseal says
@JUGHNE gave me the idea to reduce it from 2" to 1 1/4" so I have to give credit where it is due regarding that. Saved me $20 bucks atleast due to using the smaller nipple and valve as well.ethicalpaul said:Very nice skimmer you made there.My recommendation is to try about 1/3 of whatever Rectorseal says
1
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
