Thermostat CPH?
I have a Honeywell rthl2510c1002 running oil/steam boiler and noticed there’s no cycle per hour settings available.
What’s the downside of continuing with this thermostat?
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    The possibility of short cycling.
    I've found that 1-3CPH works best for pretty much everything.
  • Solid_Fuel_Man
    Edit:
    I've never seen a digital Honeywell which doesnt have the CPH setting.
    For a basic programmable stat I like the TH4110D1007.
    I've had nothing short of perfect results Honeywell's FocusPro line.
    Jamie Hall Member Posts: 27,292
    Read your manual. Function 5, Option 2
