Lighting old American gas boiler
Ecks1080
Member Posts: 4
in Gas Heating
We have an old American standard gas boiler. Model G25 fpb, series Gbr J5. I’m reading the directions but cannot find the “B” valve. Even the “A” valve is already in the OFF position and doesn’t want to go into the ON and seems to have been that way. It’s weird. I do have pictures if needed. It’s an older unit too.
Pics please.Bob Boan
Back up for pictures of all the gas piping including the pipe just outside of the unit.
We need to see the big picture.
Was this working for you last season?0 -
That doesn't look like the original gas valve, if so, the lighting instructions are not valid.
1. Turn the switch off.
2. Rotate the knob on the gas valve where it points to "Pilot".
3. Depress the red button next to the knob and continue to hold it down. Don't release it.
4. Light the pilot while continuing to hold the red button firmly down for at least one minute.
5. Release the red button. The pilot should now remain lit.
6. Rotate the knob to point to "On".
7. Turn the switch back on.
The boiler should now operate.
If the pilot does not remain lit after releasing the red button, the thermocouple is probably bad a needs replacing.Bob Boan
It was working last season yes. I’m in Massachusetts so it’s officially heat weather haha0
@Ecks1080
Hmm. Have you any experience working with gas? For safety reasons, it worries me at times to offer advice on lighting gas boilers.
From what I can tell is that the pilot valve has been removed. And from the directions offered in your picture that valve was originally installed off of the "A" valve.
So far, and without any further pictures posted. Your gas supply to this boiler has been modified and does not represent the directions posted on the boiler.
I would add a few more pictures. And , for safety sake, call a professional. Have them light the unit.0 -
Appreciate the help guys! It’s on and running. The directions on it are dumb haha0
- 15.8K Strictly Steam
