Help! Hissing Convector Radiator
The silver piece looks like it might be pushed back or slightly bent. I think the cover that is on there is not the one that was originally there and may have bent that piece.
Also, is there a way to just shut this radiator off, or does it need to be on for the others to work?
Any help is greatly appreciated.
The silver gizmo is the air vent and it looks like it's leaking. Others here can tell you what you should do and if you need to simply remove and put it back or replace it far better than I can.
Also, make sure you vacuum the convector and keep it clean for maximum heat output (and on any other convectors you have).1 -
I took a can of compressed air to it after the pics. We had insulation blown in a couple months ago and they started blowing it in there until I stopped them (You can see their hole in the top right of the first pic). We have two convectors and then standard radiators throughout the rest of the house.
Thanks for the reply! Hoping someone can advise what I should do about this.
shut off boiler remove and install a new one
That vent is usually sold at big box stores and they are known to be of low quality. Hoffman and VentRite make much better vents, just make sure it has straight threads so it will work for your convector.
Gorton and maid O Mist also make great vents but I don't know tou have room for them.Smith G8-3 with EZ Gas @ 90,000 BTU, Single pipe steam
3PSI gauge1 -
So I removed the old one and noted it had a crack from the incorrect vent cover pushing up against it.
I ran out to one of the big boxes and picked up this:
I wrapped the threads and tightened it on. I fired up the boiler this morning and it's hissing nonstop still. It's not as loud, but it's still loud and doesn't seem to stop. Is this normal. Apologies for the dumb questions, but I've never had a steam system before.0 -
Sounds like its not shutting. You mentioned that you've never had a steam system. Have you considered scheduling a tech out to check the boiler. Could you attach some pictures of the boiler?BobC said:That vent is usually sold at big box stores and they are known to be of low quality. Hoffman and VentRite make much better vents, just make sure it has straight threads so it will work for your convector.
Gorton and maid O Mist also make great vents but I don't know tou have room for them.0 -
The only vent I ever bought from HD looked just like a Maid o' Mist, but it leaked on the first day. Ever since then I've only ever bought real vents from SupplyHouse.com
I had a tech out earlier this week to service the boiler. I popped it on for the first time yesterday and noticed the cracked vent. I've now put the second vent that I got from the big box and it still hisses nonstop.mikeapolis said:That vent is usually sold at big box stores and they are known to be of low quality. Hoffman and VentRite make much better vents, just make sure it has straight threads so it will work for your convector. Gorton and maid O Mist also make great vents but I don't know tou have room for them.
Video here if it helps:
https://youtu.be/JZsHQiFqiLI
Pics of the boiler:
Are you sure it's the vent? Gingerly without burning yourself feel around to verify the source of leak.
Also that sounds like way more than the 1-2 psi that your system should be running at. I wonder if your pigtail is plugged up, "hiding" the actual pressure from your gauge and pressuretrol.NJ Steam Homeowner.
Is there a specific one needed for a convector radiator? I look up 1/8" steam vent and see multiple options on Supplyhouse.comethicalpaul said:The only vent I ever bought from HD looked just like a Maid o' Mist, but it leaked on the first day. Ever since then I've only ever bought real vents from SupplyHouse.com0 -
The first one was bent and cracked, so the vent was definitely a problem, I don't know if it is THE problem though.ethicalpaul said:Are you sure it's the vent? Gingerly without burning yourself feel around to verify the source of leak. Also that sounds like way more than the 1-2 psi that your system should be running at. I wonder if your pigtail is plugged up, "hiding" the actual pressure from your gauge and pressuretrol.
You lost me at pigtail (I'm sorry, this stuff is all super new to me). I will say that when the system is running, it's all very quiet and seems to work perfectly. It's just this one convector radiator that is making any noise. The rest of the place is heating nicely and not making a peep.0 -
Is there a specific one needed for a convector radiator? I look up 1/8" steam vent and see multiple options on Supplyhouse.comIndieRevolver said:ethicalpaul said:The only vent I ever bought from HD looked just like a Maid o' Mist, but it leaked on the first day. Ever since then I've only ever bought real vents from SupplyHouse.com
There are definitely lots of options. You have to match the thread size (1/4 or 1/8 npt) and you want a "straight" style (since your port is pointed up--many point sideways and they use an angled vent). And for a convector I'd want a nice slow vent. I'm only used to Gorton-style sizing so I don't know exactly the one to tell you, but someone else will.
But let me step back and ask you, did the sound continue even after steam had reached the vent? Or does the sound stop when the steam hits the vent? If it's the latter, then the vent you have may be OK.NJ Steam Homeowner.
The "pigtail" is the informal name of the 1/4" "syphon pipe" that is the curly pipe on your boiler that the gauge and pressuretroll are connected to.IndieRevolver said:
The pigtail keeps steam away from your controls. But it can get clogged up after a number of years if it's not cleaned out during regular service maintenance events.
If it gets clogged up, then the boiler pressure can climb too high and can damage your vents and cause many other problems. The pressuretrol's job is to turn off the boiler once the pressure reaches a threshold (hopefully about 2psi) and then allow the boiler to run again when the pressure drops to about .5 psi
I recommend this book from this site which will help you understand how this stuff works: https://heatinghelp.com/store/detail/we-got-steam-heat-a-homeowners-guide-to-peaceful-coexistenceNJ Steam Homeowner.
So is it hissing air or hissing steam? If air, that is what it is supposed to do.
Usually not that loud. But what kind of main venting do you have? If little or none, the air will vent at the radiators (or convectors) and may sound like that.0 -
The sound is nonstop as the boiler heats up and steam starts circulating. It doesn't stop while it's running. It's only after I turn the system off that the steam stops coming out.ethicalpaul said:ethicalpaul But let me step back and ask you, did the sound continue even after steam had reached the vent? Or does the sound stop when the steam hits the vent? If it's the latter, then the vent you have may be OK.
I went down to look while it was running and it seems that the PSI isn't registering on the boiler.
You should clean that pigtail or have it cleaned.
