Time to make some threads
ChrisJ
Member Posts: 16,751
Due to issues with burrs on the last units we made I'm going to be milling some female 1/8" NPT threads in 316SS soon.
The things I like about thread milling is if a break the threadmill off it simply falls out of the hole. I can also adjust it so my threads fit a specific part perfectly with little to no slop. When done right and compared I feel it makes tapped threads feel pretty terrible.
This will be my first time doing NPT threads with one.
So does the part need to rotate and move up and down the pitch of the thread as it rotates?0
mattmia2 said:So does the part need to rotate and move up and down the pitch of the thread as it rotates?
I'm going to try and take a video of it in the next few days.
I've done a lot of normal threads but this will be my first time milling npt threads
Does that mean that the tool rotates around the work, or am I misunderstanding?ChrisJ said:0 -
ratio said:
2 -
That's awesome. Do you use it to make male threads too?0
great animation!Bob "hot rod" Rohr
I have been using a high-performance two-flute PCD (diamond) threadmill at work. M24x1.25 inside threads in aluminum in about one second. 18,000 RPM and .3mm/rev (automotive left the inch system long long ago) Up to this point all I have used is been plain ‘ol Emuge carbide.Love the remark about how a broken threadmill just falls out. The threads are still usually junk, but broken taps=sadness. Broken spindles = even more sadness. G0 does not a G1 make.0
I really enjoyed reading this THREAD! or is this a POST? maybe a discussion?
I'll call it a Thread, mainly for the contentEdward Young Retired
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
