Time to make some threads
The things I like about thread milling is if a break the threadmill off it simply falls out of the hole. I can also adjust it so my threads fit a specific part perfectly with little to no slop. When done right and compared I feel it makes tapped threads feel pretty terrible.
This will be my first time doing NPT threads with one.
So does the part need to rotate and move up and down the pitch of the thread as it rotates?0
On my machine the part moves in X and Y and the tool spins and moves in Z (vertical).mattmia2 said:So does the part need to rotate and move up and down the pitch of the thread as it rotates?
I'm going to try and take a video of it in the next few days.
I've done a lot of normal threads but this will be my first time milling npt threads
Does that mean that the tool rotates around the work, or am I misunderstanding?ChrisJ said:On my machine the part moves in X and Y and the tool spins and moves in Z (vertical).
I've done a lot of normal threads but this will be my first time milling npt threads0 -
The tool spins like a drill bit and moves up and down and the part moves around horizontally.ratio said:On my machine the part moves in X and Y and the tool spins and moves in Z (vertical).
I've done a lot of normal threads but this will be my first time milling npt threadsSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
That's awesome. Do you use it to make male threads too?0
great animation!Bob "hot rod" Rohr
Living the hydronic dream0 -
I have been using a high-performance two-flute PCD (diamond) threadmill at work. M24x1.25 inside threads in aluminum in about one second. 18,000 RPM and .3mm/rev (automotive left the inch system long long ago) Up to this point all I have used is been plain ‘ol Emuge carbide.Love the remark about how a broken threadmill just falls out. The threads are still usually junk, but broken taps=sadness. Broken spindles = even more sadness. G0 does not a G1 make.0
I really enjoyed reading this THREAD! or is this a POST? maybe a discussion?
I'll call it a Thread, mainly for the contentEdward Young Retired
- 133 Chimneys & Flues
https://youtu.be/rDnavOlGcdc
