Time to make some threads
ChrisJ
ChrisJ Member Posts: 16,716
Due to issues with burrs on the last units we made I'm going to be milling some female 1/8" NPT threads in 316SS soon.
The things I like about thread milling is if a break the threadmill off it simply falls out of the hole.  I can also adjust it so my threads fit a specific part perfectly with little to no slop.  When done right and compared I feel it makes tapped threads feel pretty terrible.
This will be my first time doing NPT threads with one.
    mattmia2 Member Posts: 12,800
    So does the part need to rotate and move up and down the pitch of the thread as it rotates?
  • ChrisJ
    On my machine the part moves in X and Y and the tool spins and moves in Z (vertical).
    I'm going to try and take a video of it in the next few days.
    I've done a lot of normal threads but this will be my first time milling npt threads
  • ratio
    ratio Member Posts: 3,994
    Does that mean that the tool rotates around the work, or am I misunderstanding?
  • ChrisJ
    The tool spins like a drill bit and moves up and down and the part  moves around horizontally.
  • ChrisJ
    This video shows how it works.
    https://youtu.be/rDnavOlGcdc
    CanuckerSolid_Fuel_Man
  • ratio
    That's awesome. Do you use it to make male threads too?
  • ChrisJ
    Yessir.
    hot_rod Member Posts: 25,110
    great animation!
    without a cnc mill you would need a mill that was pretty much just built for thread cutting.
    CLamb
  • Lard
    Lard Member Posts: 115
    I have been using a high-performance two-flute PCD (diamond) threadmill at work.  M24x1.25 inside threads in aluminum in about one second.  18,000 RPM and .3mm/rev (automotive left the inch system long long ago) Up to this point all I have used is been plain ‘ol Emuge carbide.
    Love the remark about how a broken threadmill just falls out. The threads are still usually junk, but broken taps=sadness.  Broken spindles = even more sadness.  G0 does not a G1 make.
    EdTheHeaterMan Member Posts: 10,492
    I really enjoyed reading this THREAD! or is this a POST? maybe a discussion?
    I'll call it a Thread, mainly for the content
