aNOOOO! rod...note to self
HydroNiCK
Member Posts: 186
The anode rod hex head on my Rheem Fury water heater is an alloy. I tried to tack a nut onto it since I stripped it. Bad idea.
There was a magnesium rod in there but probably disintegrated. I bought this 15 year old heater with the house. After three years and my wife recently complaining the hot water was running out too fast i decided to clean it. A lot of rusty water came out. The expansion tank was filled with rusty sediment and shot. I started on the anode with a breaker bar. Then added 5' black pipe cheater and recruited my father. Then put a little Rydlyme on it and let it marinate, it seeped through the threads. I hit it with 1/2" impact wrench...and it didnt budge. After all that, the hex was stripped. At this point it was a matter of pride. Soo I hooked up the welder. Needless to say it was a bad day in water heater world. I now have a new A.O. Smith.0
Hi @HydroNiCK , A trick I use with anodes is to remove them, before the heater is installed and put a few turns of teflon on the threads, then reinstall. That way, years from now when I want to check the anode, it will be pretty simple. I know life this way has far less drama, but boring can be good sometimes
Yours, Larry1 -
that acid probably tended to dissolve the head of the anode, probably not the thing to use for that.
powered anodes are expensive but don't really require regular maintenance. I would replace the drain valve with a full port valve like this and a brass nipple so you can really flush it out:
https://www.supplyhouse.com/Webstone-40313W-3-4-Female-x-Hose-Full-Port-Ball-Valve-Lead-Free0 -
I put food grade anti sieze on my new anode.0
EdTheHeaterMan said:Food grade or not, don't just stick your anode in anywhere you like. You never know where some tappings have been. (Covid and all... Just saying)
Its ok, thats why i use RectumSeal
Or install these and forget it. https://www.nilesst.com/power-anodes/
I have them on a couple big tanks. So far, so good..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein2
- 123 Chimneys & Flues
