Utica 15b error 62
jdgarner92
Member Posts: 4
Hey everyone, fairly new to homeownership and third year in the house and the boiler keeps throwing an error 62 code, the manual just says that it’s a soft lockout with a automatic reset. My issue is that it keeps happening and was just wondering if anyone had a more in depth idea of what would cause the error could be. The boiler was originally installed in 2014. Thanks in advance!
Also I forgot to mention that it does fire up and heat the house, but after a few hours it throws the code and then you have to turn off the heat at the thermostat for the 1 hour auto reset to start0
Thanks @Ironman , gonna give someone a call so it will be nice to have a little more information to give them0
That pilot assembly can act finicky if everything isn’t right with it.Bob Boan
If that masonry chimney doesn't have a SS liner, you may not be drafting properly and be getting flue gas condensation which will eventually cause it to deteriorate. Poor drafting can also cause pilot issues.Bob Boan
