Armstrong ultra 90
rerun123
Member Posts: 7
in Gas Heating
i have a armstrong ultra 90 model number guk075d14-3a 75000 btu that i am trying to convert from propane to natural gas i need to know the orfice size for natural gas any help please
You need to get the conversion kit from the manufacturer. There's more to it than just the orifices and unless you're a qualified gas technician, I wouldn't recommend that you attempt it.Bob Boan
i have a gas tech and we have contacted armstrong and since it is 22 yrs old they have no information on it this furnace even though it is 22 yrs od has been used very little since i have an outside wood burner i just got natural gas0
and yes he can get the valve converted0
and by the way it has number 54 propane orfice if that helps0
Armstrong's response is a polite way of saying you need a more experienced gas tech. It is simple math using pressures and btu content to figure out new orifice size. There is even a rule of thumb to ball park it. If your gas tech doesn't know the math, or the rule of thumb, he is under qualified.1
thanks for your reply and he might be but he is who i have so f you could pass that math solution on it would help him and really help me i am old and need this done thank you very much for any help you could give0
Thanks for all your help for this old retired army vet0
- 15.8K Strictly Steam
