NTI legacy boiler AOS
sia
sia Posts: 3
edited October 2020 in THE MAIN WALL
Turned on my boiler and getting an AOS error code. Any tips?
  • Ironman
    Ironman Posts: 7,967
    The flue pressure switch is not closing.
    Check the intake and exhaust pipes for blockage. Checked the condensate drain line for blockage.
    Bob Boan
  • sia
    sia Posts: 3
    If the vent fan won’t run will it cause this error?
  • sia
    sia Posts: 3
    Thanks I’ll check for blockages
  • Ironman
    Yes.
    Bob Boan
  • Henry
    Henry Posts: 998
    Call a licensed professional. This is not a DYI fix.
