NTI legacy boiler AOS
sia
Turned on my boiler and getting an AOS error code. Any tips?
The flue pressure switch is not closing.
Check the intake and exhaust pipes for blockage. Checked the condensate drain line for blockage.Bob Boan
If the vent fan won’t run will it cause this error?0
Thanks I’ll check for blockages0
Call a licensed professional. This is not a DYI fix.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
