EDR of straight pipe?
Dsisson
Member Posts: 115
I have "The Lost Art of Steam Heating". I remember reading in it *somewhere* that one can use uninsulated pipe as a sort of a radiator for small spaces. I also seem to recall that it had a table that listed the EDR of different pipe sizes per foot. But for the life of me I can't find it in the book and I even wonder if I was imagining it. Can anyone point me in the right direction for a table that lists the per foot EDR for black pipe?
Why bother with a table? A few seconds with your tape measure and a friendly calculator will give it to you. Measure the circumference of the pipe in inches. Multiply that by 12 (the number of inches in a foot) and divide by 144 (square inches per square foot) and there you are. The EDR of a foot of your pipe.Br. Jamie, osb
Thank you - as I understand it:
EDR of steel sched. 40 pipe (example)
pipe size = 1"
diameter = 1.315"
EDR per foot = 0.344
correct?0 -
Here's one:
And Here's the link:
Carbon Steel, ANSI Schedule 40 (in) Datasheet
Use the numbers in the "External Surface Area" column.0
