Sizing Outdoor Heater
Danny Scully
Member Posts: 1,462
How would one go about sizing an outdoor heater?
The whole Outdoors or just your neck of the woods?Danny Scully said:How would one go about sizing an outdoor heater?
2 -
I see what you did there...10 x 10 spaces, with building overhand and one wall of building.0
In my experience it’s based on the footprint the infrared heater can cover.Steve Minnich0
Great question!
The only one that I have much experience with is this type. https://www.h-mac.com/product-catalogs/detroit-radiant/Re-Verber-Ray-HL3-Installers-Guide.pdf
If you install them at the lowest recommended height the work pretty well.
The key to all outdoor radiant products is screening the wind. You can install all the heat you want but unless you can block the wind, folks will still be cold."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
- 17 Recall Announcements
