Peerless 211
Dan Foley
Member Posts: 1,268
Brian, Dragon and Henry have been working on this one for the last few days. It is a one-pipe steam replacement in a small apartment building on Capitol Hill, about two blocks from Union Station.
Brian will fire this up tomorrow and clean/skim.
A couple more showing the 5” header.1
You have no idea how refreshing it is to see an install this good. Most boilers like this we see have completely welded headers.....All Steamed Up, Inc.
Consulting3 -
Beautiful job as always. You guys always knock it out of the park.1
Geez Steve......My guys consider those sections to be light. They're a step lighter than the WM88 ends and the 88's a step lighter than the Peerless TC's . We only take apart LGB's, never installed one... those sections are even lighter yet. We've only done one 211, I think it was a 4 or 5 section too with a single threaded riser and header.
Nice Work.To learn more about this professional, click here to visit their ad in Find A Contractor.1 -
I'm 60 years old. One back surgery and two neck surgeries. : ) I wouldn't be able to move the next day.The Steam Whisperer said:Geez Steve......My guys consider those sections to be light. They're a step lighter than the WM88 ends and the 88's a step lighter than the Peerless TC's . We only take apart LGB's, never installed one... those sections are even lighter yet. We've only done one 211, I think it was a 4 or 5 section too with a single threaded riser and header.
Nice Work.Steve Minnich0 -
Time catches up with us all. I am not out in the field much anymore so the younger ones do nearly all the heavy lifting. I'm only 6 years behind you, but no surgeries.To learn more about this professional, click here to visit their ad in Find A Contractor.0
I am 67 and still move some boilers and sections. I can still do it and I feel ok doing it.
But the problem is the next day I can't get out of bed.
46 years but I worked in the office for a few years on and off. I don.t know if that "saved me" or made it worse.
Dan,
Did you fabricate the header or have someone do it for you?Bob Boan
Bob,
Brian laid it out and brought in a welder. We don’t have welding gear.
We can thread up to 4”
5” fittings and nipples are hard to come by. No one stocks them. Welding was the best choice.0 -
That's the same place I'm at: we thread up to 4", but after that, the welder gets involved. The price of threaded 5" and above is so much higher than welded fittings.Bob Boan
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
