Peerless 211
Dan Foley
Dan Foley Member Posts: 1,268
Brian, Dragon and Henry have been working on this one for the last few days.  It is a one-pipe steam replacement in a small apartment building on Capitol Hill, about two blocks from Union Station.
Brian will fire this up tomorrow and clean/skim.
    Steamhead Member Posts: 18,242
    You have no idea how refreshing it is to see an install this good. Most boilers like this we see have completely welded headers..... :s
    Consulting
    Dan FoleyEzzyTluketheplumber
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    The side view of the drop header is beautiful. My back went out again just looking at the sections.
    Steve Minnich
    Dan FoleyEzzyT
  • EzzyT
    EzzyT Member Posts: 1,378
    Beautiful job as always. You guys always knock it out of the park.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Dan Foley
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,313
    Geez Steve......My guys consider those sections to be light. They're a step lighter than the WM88 ends and the 88's a step lighter than the Peerless TC's . We only take apart LGB's, never installed one... those sections are even lighter yet. We've only done one 211, I think it was a 4 or 5 section too with a single threaded riser and header.
    Nice Work.
    Dan Foley
    EBEBRATT-Ed Member Posts: 19,691
    Nice Job!
    You have to be able to measure good to do a job like that and make it look good
    Dan FoleySTEVEusaPA
  • Steve Minnich
    Nice Work.
    I'm 60 years old. One back surgery and two neck surgeries. : ) I wouldn't be able to move the next day.
    Steve Minnich
    Time catches up with us all. I am not out in the field much anymore so the younger ones do nearly all the heavy lifting. I'm only 6 years behind you, but no surgeries.
    I am 67 and still move some boilers and sections. I can still do it and I feel ok doing it.
    But the problem is the next day I can't get out of bed.
    46 years but I worked in the office for a few years on and off. I don.t know if that "saved me" or made it worse.
  • Ironman
    Ironman Member Posts: 7,878
    Dan,
    Did you fabricate the header or have someone do it for you?
    Bob Boan
  • Dan Foley
    edited October 2020
    Bob,
    Brian laid it out and brought in a welder.  We don’t have welding gear.
    We can thread up to 4”
    5” fittings and nipples are hard to come by. No one stocks them.  Welding was the best choice.
  • Ironman
    That's the same place I'm at: we thread up to 4", but after that, the welder gets involved. The price of threaded 5" and above is so much higher than welded fittings.
    Bob Boan
  • Ironman
    As always, it looks great.
    Bob Boan
    Dan Foley
