Hartford loop
Snowmelt
Member Posts: 1,457
Not my job, but if the Hartford loop isn’t set up with a close nipple what will happen?
Not my job
Not my job
The Hartford Loop should not use anything longer than a shoulder nipple. I used the extra heavy nipples.
Using a long piece of pipe allows scale or dirt to collect in the pipe. This could cause at some time in the future the slowing down of water flow into the boiler. Rare occurrence but possible.
Sometimes under the right conditions severe banging will occur.
It looks like only one side is connected to a Hartford Loop and what is that brass gizzmo in the T.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Lol 8 saw that also, looked like he was going to attach pex to it0
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
