Should I remove powder coating from brass union nipples?
MountainSteam
Member Posts: 20
I had a few of my 2 pipe steam radiators powder coated. The shop said they would mask the brass union nipples that connect the radiators to the valve and traps. The radiators look great, but half of the union nipples have powder coat spray on the union nipples or in the nut's thread, or both.
The images below illustrate the range of the over spray:
- In some cases a few specs or a dribble is on the brass union nipple
- In some cases there is over spray on the union nut's threads
- In some cases the entire union nipple has powder coat spray on it
- Ignore the over spray and fasten the radiators and hope for the best?
- Gently scrape the brass unions clean and leave the nut threads as the are? If so, is there a preferred tool? Solvent?
- Buy new unions? If so, what tool is best to remove and replace the unions? The unions are short and a pipe wrench is too wide to fit between the union's nut and the radiator.
- Do something else?
Probably not a problem. Little scotchbrite will take it right off.
There is a special spud wrench to remove the spud from the radiator that firs inside to extract it. they are notoriously difficult to extract.0 -
I consider that tool to only be for installing new spuds.
If those were mine I'd take the time to clean the mating surfaces but don't scratch them.
To seal metal to metal the surfaces need to be near perfect.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Those mating surfaces have to be perfectly clean, but they must also be perfectly smooth. Do not use anything which might scratch them. Scotchbrite probably will work, but I'm not quite as optimistic as @mattmia2 -- powder coat is likely to be really on there, and you have some work to do.
Lucky you, though -- the threads don't matter. Not to worry about them.Br. Jamie, osb
I tried using a pad wrench to remove the spud on a 110 y/o radiator and a newer that was probably only 20 years old. They both laughed at me I think. A sawzall had 4 careful cuts in it and a cold chisel knocked it out. Probably took less than 10 minutes to remove. Easy. Spud wrench tightened the new one in.
Actually had to change the bushing as well from 1-1/2” to 1-1/4”. Cut that out too. Similar way. 4 or 5 notches just short of the threads then use a 36” pipe wrench and they collapse Inward With the force and thread right out. Another win for tapered threads.
Unless tape was used, probably not coming out. the brass is soft and the spud wrench will easily tear off the notches. Maybe some rot of impact might have worked.0
- 116 Geothermal
- 15.8K Strictly Steam
