Honeywell's Heat Generator
HeatingHelp
HeatingHelp Administrator Posts: 718
edited September 2020 in THE MAIN WALL
In this excerpt from his Classic Hydronics seminar, Dan Holohan teaches us about Mark Honeywell’s Heat Generator.
Watch the video here
luketheplumber
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    If you encounter one on the job, please be cautious because it is filled with pure mercury.
    President
    HeatingHelp.com
    luketheplumber
  • luketheplumber
    luketheplumber Member Posts: 160
    I have pulled so many mercury bulbs from old thermostats that people have thrown in dumpsters. I still have them but they are stored safely an a double container with newspaper to cushion the fragile glass bulbs.
    Located in durham NC.
  • JUGHNE
    JUGHNE Member Posts: 11,513
    If you keep the tstat intact then most HVAC supply houses will take them for recycling.
    I did not know that as I also have removed the bulbs and my supply houses do not want bulbs only. So I too have a collection.
    Some areas have toxic waste collection points that might accept them. Best to get rid of them ASAP.
    luketheplumber
  • luketheplumber
    @JUGHNE Yeah I could dispose of them properly, but I think mercury is a cool thing to have. I of coarse store it safely and securely. I have showed it in online school it several classes and to several friends of mine. I will definitely keep it in the glass for now.
    Mercury is just and interesting metal to look at and show others and I am certainly aware of the dangers of it and handle it with extra care and safety.
    Jamie Hall Member Posts: 26,839
    If you do decide to take them for recycling, be very sure that your recycling facility can and will accept them. A number of facilities either can't, or won't.
    luketheplumber
  • luketheplumber
    @Jamie Hall I'm pretty sure that my local recycling center will take them if the time comes when I want to get rid of them.
