can a power-vented gas water heater share its circuit?
weil_fail
Member Posts: 84
is it okay to plug a gas water heater into an outlet on a circuit with other things? the current draw for the fan and igniter is roughly 3A max, so it shouldn't be an issue from a breaker/wiring standpoint, but I'm wondering if USA electrical code requires it to be on its own circuit. Is anyone familiar with this?
It's okay as long as it, and the other things, don't overload the circuit.Bob Boan
Any appliance (like the water heater above) that does not require it's own branch circuit due to it's relatively small load and is FASTENED in place, water heater, window ac units etc can be used on a general use branch circuit provided the equipment fastened in place on that circuit does not exceed 50% of the branch circuit rating. So 7.5 amp max for a 15 amp circuit and 10 amps for a 20 amp circuit0
Doesn't mean it is always best practice but it is allowed0
I've got a dehumidifier + pump and all of my internet modem / router / switches and the recirc pump and Ecosteam sharing with my power vent heater. All of its such low consumption it doesn't matter. Well, the dehu isn't but it's not huge either.
- 116 Geothermal
- 169 Indoor-Air Quality
