gas explosion
SlamDunk
Member Posts: 1,807
in Gas Heating
https://www.cnn.com/2020/08/10/us/baltimore-maryland-house-explosion/index.html
This is becoming a monthly occurrence.
Sad. Wonder if it was something in the house or a main.
I wonder if plastic gas lines are as safe as steel gas lines. They seem to be prolific in my neck of the woods.0
Plastic gas lines?SlamDunk said:I wonder if plastic gas lines are as safe as steel gas lines. They seem to be prolific in my neck of the woods.
We have Polyethylene in NJ but it's only allowed outside and underground.
Locally, we had a house lifted off it's foundation when an HVAC tech lit his acetylene torch in its crawlspace
last week. There was a natural gas leak repair where the polyethylene connected with the main a couple weeks earlier. According to the local news, the torch kit involved was missing. Thegas company says without being able to inspect the missing torch kit, they won't assume responsibility. The tech was injured. I have to find that story.
Here it is...My memory of details isn't great
https://abc11.com/raleigh-explosion-courtland-drive-garner/6360064/0 -
This was in a rowhouse neighborhood that is said to have been built around 1960. It's a few miles from my house.
As of now, search-and-rescue teams are still working. It'll be a while before we know what went wrong.All Steamed Up, Inc.
Consulting0 -
The article doesnt discuss extent of injuries but I have a hard time believing a leaky torch could lift a house "6 inches" into the air. He didnt look very hurt running away in video.0
Acetylene has a little more kick than NG.SlamDunk said:The article doesnt discuss extent of injuries but I have a hard time believing a leaky torch could lift a house "6 inches" into the air. He didnt look very hurt running away in video.
Actually, it has a lot more kick.
Aside from that I have no idea.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Latest news reports confirm the gas mains in that neighborhood were installed in the 1960s . So they are probably not the original cast-iron with doubled lead-and-oakum joints.
I'm guessing that whatever went wrong, happened inside one of the houses.All Steamed Up, Inc.
Consulting0 -
<<He said he moved aside debris, including parts of a fence, and he heard the gas hissing.>>
Most catastrophic gas explosions are caused by underground gas leaks on gas mains or gas services to buildings.
Gas saturates the ground, then it migrates underground to basements or crawl spaces where it accumulates to an explosive level (4-14% gas in air for natural gas.
Finally, a spark or other ignition source ignites the gas, which goes off as an explosion which blows the building off the foundation. Then the rest of the building collapses into the basement or crawl space.
When I was a first responder for the local gas company, we were trained to take underground gas readings around the foundation of the building before going inside. If we found explosive levels of gas at the foundation, we called the fire department to evacuate the nearby buildings.
There were lots of leaks on gas mains. The company had an elaborate program to track the conditions of these leaks and take immediate action if they became a hazard. But most were managed by drilling holes in the street which allowed gas to escape into the atmosphere.
Plastic (polyethylene) gas mains and services were a LOT less likely to leak than older steel or cast iron equipment.2
