Discovered mold on pipes
Hello, we had the ceiling soak through from a leaking ice maker line. It had probably been running for a few days, so it got really wet in the basement ceiling. I tore away the rotted drywall and discovered moldy pipes.
I was planning on cleaning off the pipes and replacing the drywall now that the ice maker line has been replaced. But should I keep digging in the ceiling for more mold? Need advice!
Thanks so much, Nick
Probably. I would, anyway. No telling how far the moisture went. Any insulating material that got wet or even damp needs to go. Wipe any wood with bleach or a good mold eliminator product (careful with that stuff -- read ALL the safety instructions! Goggles. Gloves. Old clothes or tyvek coverall. Etc.)Br. Jamie, osb
Thank you very much, Jamie!
If I cut through and extra foot or so and don't notice any more mold can I call it OK?0 -
Most likely.Br. Jamie, osb
- 117 Geothermal
