ABS solid pipe available?
CLamb
CLamb Member Posts: 341
edited July 2020 in Plumbing
Is ABS solid pipe available anywhere near central New Jersey? I've called around and can only find foam core or cell varieties. I prefer solid for it's stiffness and durability.
  • JUGHNE
    JUGHNE Member Posts: 11,502
    Not available in my area. There is a little of it here from about 30 years ago.
    I find PVC sch 40 seems to be stronger, looks better and no special glue for transition.
  • Zman
    Zman Member Posts: 7,611
    I think it is like the Unicorn. I have read about it in books but never seen one....
    Albert Einstein
    CLambkcopp
  • EzzyT
    EzzyT Member Posts: 1,377
    @CLamb why don’t you just switch over to pvc which is available everywhere? As per code you must use a no-hub couplings to make the transition from ABS to pvc. Transition glues not allowed as per code.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    kcopp
