ABS solid pipe available?
Not available in my area. There is a little of it here from about 30 years ago.
I find PVC sch 40 seems to be stronger, looks better and no special glue for transition.0 -
@CLamb why don’t you just switch over to pvc which is available everywhere? As per code you must use a no-hub couplings to make the transition from ABS to pvc. Transition glues not allowed as per code.1
- 120 Geothermal
