Weil McLain cga 5
Snowmelt
Member Posts: 1,415
I have a 3 year old cga that I am taking out of a customers house. Like I said irs only three years old, one of my friends wants it but it’s just a little bit oversized. What’s involved in reducing the gas input/ output? Is it as simple as blocking off a burner. Is that going to effect the flow size? Hypothetical the existing boiler is 102 output and I only need 75, how would you go about doing this?
You cant. And really should not. Boiler is designed to run w/ the orifices' provided. By you messing w/ that you could get sooting and excessive CO.
Ok thanks, what about lowering the W.C in the gas valve?0
Same. The boiler was tested at 3.5" manifold pressure with all the burners. You mess with it, it's on you.0
If you're putting it in a high mass system...ie radiant floor or gravity conversion... the extra capacity really shouldn't be a problem. If you're running low mass, IE fin tube baseboard... then I might have a concern, especially if zoned.To learn more about this professional, click here to visit their ad in Find A Contractor.0
I would not even worry about the over size other than fuel cost. Can't tell you the number of times I have seen boilers way over sized. I have taken 250K out and put 140K in.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
