80 gallon electric water heater needed
zepfan
Member Posts: 451
Does anyone know of a manufacturer that still makes an 80 gallon electric water, single phase? This would be for a residential replacement, of an existing 80 gallon. thanks to all
Gotta be commercial or it’s a heat pump0
Hi @zepfan , Two forties, in series might do what you want, though I'd see if there was any possibility of dealing with the load differently. What is the load that wants eighty gallons?
Yours, Larry1 -
The homeowner has an existing 80 gallon. They also have a whirlpool that is the reason they want to go back with 80 gallon.
Thanks to all that responded0 -
All of the manufacturers still make these tanks . In Massachusetts such an installation would be non code, anything over 55 gallon is commercial now . I understand because of federal rules this applies to the whole country. There are benefits going with a 50 gallon tank and a mixing valve. Set up correctly the output should higher than 80 gallon tank , It would keep your operating costs down (when not being used for high output) as well as reducing any chances of Legionella or any other bacteria buildup in the tank.1
- 116 Geothermal
- 169 Indoor-Air Quality
