Source for Orifice
Zman
Zman Posts: 7,614
Hi all,
I am having trouble with a Dometic RV fridge that runs poorly at altitude. The manufactures solution is to not to run it on propane at altitude. That simply won't work as I really only camp off grid at high altitude.
In the past, I have brazed orifices closed and then re drilled them to a smaller size. This particular orifice seems to have glass in the nozzle so I am not very optimistic about that technique. I would also like to save the original in case I take the rig to the beach.
The threads measure 8mm diameter and 10mm long. From experience and adjusting the tables to compensate for ~35% less air density, I am thinking I need one around 63 to replace the 58 it came with. I can always redrill larger if needed. I will of course be performing a combustion analysis :D .
Does anyone know of a source for random orifices like this? Other thoughts?
Albert Einstein
    hot_rod Posts: 28,352
    Can you buy a spare #53. Might try and epoxy that opening and redrill?
    Or orifices.com :)
    Zman
  • Zman
    Zman Posts: 7,614
    Hey, there's no such thing as orifices.com (there should be though) ;)
    I would think that epoxy would melt? I could try and if it did not work I could drill everything out and braze it shut that way. The OEM orifice is expensive and hard to find. I would need to find a backup before I tried anything. It is camping season after all..
    Albert Einstein
    Buy an 8mm brass bolt, take it and the current orifice to a local machine shop, that's and easy build on a lathe. Take a handfull of bolts and drill for various altitudes :)
    You could almost do that with a drill motor and a file :) Or drill motor and bench grinder. Chuck the bolt into the drill, file or grind away away part of the hex to get the rounded shoulder where the burner attaches.
  • Zman
    Zman Posts: 7,614
    It's funny you said that. I was just looking at my drill press and scratching my head. ;)
    Albert Einstein
  • Zman
    Zman Posts: 7,614
    Argh!, The caliber says it is 8mm but it does not match any 8mm threads.
    I am going to buy the OEM orifice and Frankenstein it...
    Albert Einstein
    mattmia2 Posts: 18,107
    standard 8mm bolts are 1mm pitch, right?
    edited July 2020
    looks like a standard m8 is 1.25mm pitch
    but look for manufacturer names on the valve and other controls, they must have bought it from someone.
  • DanHolohan
    DanHolohan Posts: 16,735
    Tunstall has orifices.
    Retired and loving it.
    Zman
  • unclejohn
    unclejohn Posts: 1,833
    There is a "orifice.com" it's on the dark web. A friend told me.
    ethicalpaulZman
  • Zman
    Zman Posts: 7,614
    @unclejohn
    I'm not sure that is the kind of "orifice" I had in mind :/
    Albert Einstein
