Laziness Can Be Expensive
Sometimes I just don't want to take the time to reduce and then increase the size of piping between boiler and manifold even though it's way overkill and more expensive.
Ironmankcopp
  • GroundUp
    GroundUp Member Posts: 2,465
    That extra $8 probably isn't much of a concern when they just spent 5 figures to heat 600 sq ft
    Alan (California Radiant) Forbes Member Posts: 4,640
    edited July 2020
    More when you include the larger air eliminator and pump flanges.
  • Ironman
    Ironman Member Posts: 7,855
    Well, I think I would have done the same.
    Nice work.
    Bob Boan
  • kcopp
    kcopp Member Posts: 4,628
    Nice.
    I love that boiler. very simple but effective.
    BTW... where does the expansion tank connect into that piping?
    EBEBRATT-Ed Member Posts: 19,562
    I have done the same sometimes because it eliminates reducers.
    I like reducing tees or 90s (with fitting reducers if propress) and try to avoid bell reducers
    edited July 2020
    kcopp said:
    Nice.
    The blue x-tank is for DHW. The heating tank is upper left, almost out of view.
    ...........and I just realized I'm pumping towards the expansion tank. Rookie move and I'll change it when we go back.
