Laziness Can Be Expensive
Member Posts: 4,002
That extra $8 probably isn't much of a concern when they just spent 5 figures to heat 600 sq ft0
Well, I think I would have done the same.
Nice work.Bob Boan
Nice.
I love that boiler. very simple but effective.
BTW... where does the expansion tank connect into that piping?0 -
I have done the same sometimes because it eliminates reducers.
I like reducing tees or 90s (with fitting reducers if propress) and try to avoid bell reducers0 -
The blue x-tank is for DHW. The heating tank is upper left, almost out of view.kcopp said:Nice.
...........and I just realized I'm pumping towards the expansion tank. Rookie move and I'll change it when we go back.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
