Can I run supply in the wall down to baseboard units?
Jay_5133
Jay_5133 Member Posts: 1
I am currently remodeling an old farmhouse and will be installing baseboard units. In one area of the house I am unable to run supply and return lines from below. My question is can I run the supply and return lines in the wall down to the units? I'm concerned with air being trapped at the high point in the ceiling?
  • Ironman
    Ironman Member Posts: 7,945
    With proper purge valves and a manual vent at the high points, it should be fine.
    Also, keep the piping and pump sizing to maintain 3-4 FPS velocity.
    Bob Boan
    Jay_5133
    EBEBRATT-Ed Member Posts: 20,969
    And if they are in an outside wall make sure to keep them on the warm side of the insulation
    Jay_5133
  • Big Ed_4
    Big Ed_4 Member Posts: 3,578
    edited July 2020
    Water will freeze , attics and outside walls are avoided . Find a better way ...
    Jay_5133
    Too many unknowns. Inside wall or outside wall? Heated space above or attic above?
