Can I run supply in the wall down to baseboard units?
Jay_5133
Member Posts: 1
I am currently remodeling an old farmhouse and will be installing baseboard units. In one area of the house I am unable to run supply and return lines from below. My question is can I run the supply and return lines in the wall down to the units? I'm concerned with air being trapped at the high point in the ceiling?
Too many unknowns. Inside wall or outside wall? Heated space above or attic above?0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
