Source for Orifice
Zman
Member Posts: 7,611
Hi all,
I am having trouble with a Dometic RV fridge that runs poorly at altitude. The manufactures solution is to not to run it on propane at altitude. That simply won't work as I really only camp off grid at high altitude.
In the past, I have brazed orifices closed and then re drilled them to a smaller size. This particular orifice seems to have glass in the nozzle so I am not very optimistic about that technique. I would also like to save the original in case I take the rig to the beach.
The threads measure 8mm diameter and 10mm long. From experience and adjusting the tables to compensate for ~35% less air density, I am thinking I need one around 63 to replace the 58 it came with. I can always redrill larger if needed. I will of course be performing a combustion analysis
Does anyone know of a source for random orifices like this? Other thoughts?
Albert Einstein
Albert Einstein
Hey, there's no such thing as orifices.com (there should be though)
I would think that epoxy would melt? I could try and if it did not work I could drill everything out and braze it shut that way. The OEM orifice is expensive and hard to find. I would need to find a backup before I tried anything. It is camping season after all.."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Buy an 8mm brass bolt, take it and the current orifice to a local machine shop, that's and easy build on a lathe. Take a handfull of bolts and drill for various altitudes
You could almost do that with a drill motor and a fileOr drill motor and bench grinder. Chuck the bolt into the drill, file or grind away away part of the hex to get the rounded shoulder where the burner attaches.
Argh!, The caliber says it is 8mm but it does not match any 8mm threads.
I am going to buy the OEM orifice and Frankenstein it..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
standard 8mm bolts are 1mm pitch, right?0
looks like a standard m8 is 1.25mm pitch
but look for manufacturer names on the valve and other controls, they must have bought it from someone.0 -
Albert Einstein0
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
