Heating Vent Cover
bfroggie2
Member Posts: 2
I am fixing up my living room and had the old vent cover removed and need to put a new one on. The house was built in 58 and the problem is the vent sticks out of the wall. I would like to make it flush. Is that possible? I don’t know why it was not built flush originally. Thank you
Yes... it's possible. Is it easy? No. Problem is the sheet metal ducting to which the cover was attached also sticks out from the wall, if I read the first picture correctly, and that will have to be cut back flush with the wall, or at least parallel to the wall down from the upper edge. Also, make very sure that you don't restrict the opening at the bottom into the duct work.Br. Jamie, osb
Are you certain that hot air comes out of it?
From what I have seen these were the supply registers for gravity flow furnaces.....no blower. They needed the large opening to get the hot air moving. Usually the floor might have been cut open under the extension going out from the wall. 1958 would perhaps have been the last of gravity or this design. Just a carry over as forced air came alone.
Sometimes there would be wall stack ducting inside the wall going up to the next floor. Some had damper to direct some air up the wall stack or into the room.
If people do not mind the looks and most do not, they are great for cold air returns being on the inside wall. Then cut floor registers on the outer perimeter of the house. This involves all new ducting of course.
If you close it up to a flush wall grill be aware that a smallish grill will give you more noise if it is a supply vent.1 -
Thank you for the info very helpful I have 1 more question what is this vent in the floor for? It is in the living room by the stairway down to the basement. I am leaving it alone but curious to know it’s purpose. It 30”x12”.
Thanks again for info!0 -
That looks like an in the floor return air grill.
Is the bottom closed up across the floor joists?
It may be connected via floor joists cavities to your furnace.
They are great at collecting dirt and debris.
Or they may have just wanted some air venting from first floor to basement.0 -
Are you sure this house was 1958? This looks more like 1930's.0
The collar looks telescoping. If you drill out the rivets and nails, you should be able to slide it back till the flanges meet the studs.
You'll have to trim the bottom so as to not close off the feed duct.
Then you can mount a VM type supply register.
But realistically, the whole thing isn't right. It's not even a duct. It's an opening in the wall. I bet the return "duct" is just flat metal panned to a couple ceiling joists in the basement. Forget about A/C. I'm sure the whole distribution system needs repair, replacement, insulation, air sealing. The Joy's of being a homeowner.0 -
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
