(not again....) can we identify this hydronic baseboard?
Bob Vennerbeck
Member Posts: 107
I harbor no fantasies about getting matching baseboard or accessories, but I would love to identify this residential hydronic baseboard - rear panel with full length hanger formed for front assembly stands 10" off the floor; enclosure front has brackets spot welded to top and bottom panels - can't really tell if vane is welded in, or clipped in - it's very much PAINTED in, and I'd hate to mess it up trying to move it....
Yes - the cat fur and carpet almost completely block the bottom of the front panel - might be able to remount the whole shebang about a 1/2" higher without messing up the piping.
Vbob
Vbob
Ironman - apart from being fully installed, not leaking, and performing to the resident's satisfaction, what else do you see wrong with it?
I remain curious about its provenance, and plan to clean it up as I have occasion to do other work in each room. Whether the vanes are designed to move or not may have to remain a mystery, because removing the paint to find out makes this a much larger project.0 -
Ebebratt-Ed & Big Ed_4 - thanks! Your cleaning suggestion is pretty much what I thought of trying, once I get the sprayer back from the gardening half of the team. If I ruin the carpet I won't be heartbroken..... The fin-tube is entirely traditional aluminum on copper and could be swapped out if need be; but the enclosure is 10" high and the walls were paneled down to the top of enclosure, so lots of fussy patching or added trim would be involved in replacing that. Doing nothing at all is still an acceptable option, up until I do more than just pop the covers off.
Get a fin comb or needle nose pliers and straighten them as best as possible, you need good air flow thru the fins to get rated output.Bob "hot rod" Rohr
The first pic indicates that the paneling comes half way down behind the BB's enclosure. You can see it in the crack between two sections.mattmia2 said:I would handle the paneling coming to the top of the case by bringing the new case up to the bottom of the paneling. An extra couple inches underneath just means better airflow and less issues with carpet and other objects on the floor impeding airflow.
Bob Boan
Have seen it before, but don't know who made it. Doing a Google search it looks similar to a product made by Q mark, maybe an older version? They make hydronic and electric baseboard heat.0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 164 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.6K Strictly Steam
