life of a indirect hwh
jerryb46
Member Posts: 60
how long would a stainless indirect hwh last on long island N.Y. Soft water,low clor count 20 yrs old now ?
You might want to think about stone lined. Really depends on water condition.0
Hi, I agree with @Zman that 20 years isn't bad. If you can change anodes as needed, a glass lined tank can last a very long time as long as pressure is controlled. I've gotten fifty years from glass lined tanks.
Yours, Larry0 -
Do indirect's have an anode?0
Some do, some don't. Most stainless models do not."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I would think glass lined indirect water heaters would have a anode rod.
SS indirect water heaters can be destroyed by high clordies plus there are different grades of stainless steel.
Stone lined indirect water heare from Vaugh is a good unit. Vaughn also builds a plastic indirect water heater called their Featherweight.0 -
Both of my original Buderus tanks went over 20 years ... one made it to 25. The new thermoglass are about 1/2 the weight and I was reading about failures -- replaced both w/ stainless. No anode in B stainless tank .. yes in the thermoglass0
thanks for the answers great knowledge from the pro's0
- 116 Geothermal
- 169 Indoor-Air Quality
