Shutting Down For The Summer.
JackW
Member Posts: 236
Looks like warm weather is finally here in NW Ohio, what is the proper shut down procedure for the summer months. Before I redid my system I just drained the top half and left the water in the floor then would flush it all out before firing it up in the fall. I know the water is dirty because I can see it in the strainer, plus I'm using a micro boiler now so I want to make sure it's clean, along with the lines and pumps before I fire it up in the fall. Do they make any kind of a cleaner that can be run through the system for that purpose? Also should I leave the system full or empty for the summer? Any other advice will be greatly appreciated.
Thanks,
Jack
Thanks,
Jack
@HVACNUT my concern is the dirty the water that appears in the strainer. I don't know where that came from but I worry it might cause problems inside my boiler. I remember seeing a post that someone recommended using a cleaner of some sort, it consisted of two pressurized cans.0
You definitely don't want to drain your boiler. Oxygen is your enemy with a boiler. Anytime you add fresh water, air and oxygen are added. This can increase the potential for corrosion inside your circulator and any other ferrous metals in your system. That strainer is ok, I'd rather have a magnetic dirt separator. I've used 8 way boiler treatment in my boiler at home. What do you have for domestic hot water? That boiler looks like it would go with an indirect tank. 😉2
@SuperTech my system runs off of a micro boiler. I was looking for something to run through the system to clean it out.0
Was the system properly cleaned when installed?
If not I would run a cleaner, flush, refill with good water and then add the second can of hydronic treatment.
Assuming the system is leak free, it should be sealed off, labeled, and last for 20 years.
All system fluid will get some color to the water, the systems with inhibitors tend to run grey, non inhibited plain water systems will run a bit red, indicating the ferrous metals have rusted from any O2 in the system. It's almost impossible to keep perfectly clear water in a hydronic system.
Rhomar is a good brand of inhibitor/ cleaner kits. A few others offer the two can cleaner/ conditioner packages.Bob "hot rod" Rohr
Living the hydronic dream2 -
@hot_rod thanks. The color of the water is rusty looking red. I didn't clean anything when I rebuilt it so I will do it now. Is the cleaner kit from Rhomar the "Hydro-Solv™ QC Aerosol Hydronic System Cleaner" below?
http://www.rhomarwater.com/Hydronic_Treatment.html
yes this is a simple DIY kit.JackW said:@hot_rod thanks. The color of the water is rusty looking red. I didn't clean anything when I rebuilt it so I will do it now. Is the cleaner kit from Rhomar the "Hydro-Solv™ QC Aerosol Hydronic System Cleaner" below?
Word of caution, be sure you have it connected tightly on the hose connection, the can empties in a few seconds!
Living the hydronic dream1 -
Thanks @SuperTech I'll look into that.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
