recommended make/model of condensate pump for mini-split?
hey,
I plan to install a condensate pump to push mini-split condensate up about 11-12ft. it's a 9k btu indoor unit. any recommended products for this? what's the best way to push water that high? any tips/tricks for best results?
    HVACNUT Member Posts: 7,308
    Little Giant.
    pecmsg Member Posts: 6,894
    Find a new location for the head.
    Hot air rises, cold air falls............….Pumps fail, Walls and ceilings get damaged.
    EBEBRATT-Ed Member Posts: 19,905
    Why not drain it down into your crawl space and pump or gravity drain it from there
  • weil_fail
    weil_fail Member Posts: 84
    @EBEBRATT-Ed , I wish that was an option. unfortunately, I have to go up first.
