Singer air conditioner
matthawkins
matthawkins Member Posts: 1
Hello I was trying to find the tonage of my singer ac and the numbers on back are gone. But i pull off the plate on condenser. Has BM700676
    EBEBRATT-Ed Member Posts: 18,010
    Look inside the electrical compartment. Sometimes there's numbers in their.
    If you get model and serial # off compressor body we can find it that way
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    Is that the treadle operated model?—NBC
    pecmsg Member Posts: 6,204
    It really doesn't matter what the old one was. Get a heat load loss calculation performed. See if the duct system can handle the new air flow requirements. A lot of changes since that unit was installed.
    Steamhead Member Posts: 17,846
    Singer was something of a conglomerate several decades ago. Besides HVAC equipment, they were in the audio-visual field (with Graflex) and transportation signalling (Safetran). Those are just the ones I know of............
    Consulting
    mattmia2 Member Posts: 13,126
    I had a b&w 13" tube tv that was singer branded. I had another one with an identical chassis that was panasonic branded.
    HVACNUT Member Posts: 6,801
    My brain went to sewing machines. Not them? I haven't seen one in forever. Always assumed it was the same Singer.
    SuperTechmattmia2
    It was.
    Consulting
    HVACNUTmattmia2
    Singer was bought and sold and changed names a few times. I think it was Climate Control at one time
